LPB
Прогресс-2
HONDA BF-30
Our Price: $1,352.91
Sale Price: $1,428.43
Product Code #: PK-M9-A450
The following items are included in this package:
Click on the Item for more information on that Component
* 6 of Cable "Carolprene" Flexible Fine Strand Welding Class K, 4 Gauge - Black ($7.74 value!)
* 6 of Cable "Carolprene" Flexible Fine Strand Welding Class K, 4 Gauge - Red ($7.74 value!)
* 1 of Alltrax Controller AXE7245 24-72 VDC 450 Amp Peak PM or Series Programmable ($697.79 value!)
* 1 of Fuse ANL/ANE Holder ($16.94 value!)
* 1 of Fuse ANL 300 Amp ($4.98 value!)
* 4 of Lug Magna Straight 4 GA 3/8" Hole ($5.96 value!)
* 2 of Lug Magna Straight 4 GA 1/4" Hole ($2.56 value!)
* 6 of Lug Magna Straight 4 GA 5/16" Hole ($8.94 value!)
* 1 of Motor MotEnergy ME0709 Permanent Magnet DC Pancake Brushed ($599.00 value!)
* 1 of Throttle Magura 0-5K Twist Grip 70" Wire ($59.95 value!)
* 1 of Red Keyed Master Cutoff Switch 500 amp ($16.95 value!)
Our Price: $2,166.29
Sale Price not including Controller & Throttle $2,129.00
Availability:: Usually Ships in 24 Hours
Product Code #: PK-D135-400
* 2 of Battery Terminal Clamps Brass Pair with Wing Nut ($10.98 value!)
* 8 of Cable Welding 2 Gauge - Black Sold by the Foot ($15.92 value!)
* 8 of Cable Welding 2 Gauge - Red Sold by the Foot ($15.92 value!)
* 1 of Fuse ANL 500 Amp ($8.99 value!)
* 2 of Lug Magna Straight 1&2 GA 1/4" Hole ($4.12 value!)
* 6 of Lug Magna Straight 1&2 GA 5/16" Hole ($12.36 value!)
* 4 of Lug Magna Straight 1&2 GA 3/8" Hole ($8.24 value!)
* 1 of Motor Lynch LEMCO LEM200-D135 84 VDC with double magnets ($1,958.46 value!)
LPB
Прогресс-2
HONDA BF-30
http://www.fortbendboats.com/id23.html
Магазин по электромоторам и пр. лабудени
http://www.electricmotorsport.com/store ... motors.php
И ВОТ, ЧТО ДОКТОР ПРОПИСАЛ-понравился. :D
Высокая Производительность переменного тока-9 Двигателя с Кертисом Regen Контроллер
Кертис Regen модель Контроллера 1234-5371
Пиковая Мощность @ 48 Вольт Номинал:
350 Amp
10 л.с.
44 ft/lbs Пик
C-Face
Вал привода: 7/8" dia, 1/4" Паз, 2.50" долго
Двигатель Длины (не включая валы): 12.488" Долго
Мотор Диаметр: 7.132"
Лицевая панель Пилот (Регистрации): 4.5"
Монтажными Отверстиями: Кол-во (4) 3/8"-16 нить,3.875" до н. Э.
Вес: 48 кг.
Особенности:
* Напряжение системы: 48 вольт, 6 или 8 Аккумулятор можно использовать системы. 36-вольтовой системы должны быть повышен до 48 вольт.
* Мощный: Наша переменного тока, Двигатель имеет высокий крутящий момент, лучше ускорение и холм альпинизм возможностей, чем обычные DC системы, не жертвуя Дисков способность или Эффективность.
* Рекуперативного Торможения: Восстанавливает обратно к батарей до нулевой скорости уменьшения использования механических тормозов, увеличение времени выполнения, также не позволит автомобилю, чтобы бежать вниз. Чем круче в гору означает больше энергии обратно на батареях, так же, как 150 АМПЕР!
* Питание под Контролем: иметь много питания не означает потери контроля. Наши Системы переменного тока имеет очень точный контроль скорости.
* Гольф Режим: В гольф Режим, уменьшается скорость до 12 км / Ч, а также ускорение и рекуперативного Торможения уменьшается для предотвращения потери тяги на траву. Хилл альпинизм момент НЕ уменьшается.
* Улица Режиме: 25 км / Ч, Увеличил ускорение и Полный Регенеративного Торможения.
* Многофункциональный Дисплей: Обычно используется в качестве Спидометра и для текстовых сообщений.
* Limp Home Mode: С AC Системы, ухудшения, очень мало, как напряжение батареи падает, поэтому мы построили в "Limp Режим", чтобы вы дома, когда батареи низкий. Это будет капля максимальная скорость примерно до 15 км / Ч.
* Эффективность: Хотя это очень мощный, системы переменного тока, также очень эффективно, с 20 до 40% меньше Энергии, драйва время, безусловно, будет увеличен.
* Миль по обвинению: "БОЛЬШОЙ" Вопрос. Существует множество факторов, влияющих на то, как далеко вы пойдете на заряд, Скорость, Местности, вес, Тип и количество аккумуляторных батарей являются основными. Одна вещь, это точно, вы будете идти дальше с системы переменного тока, чем вы будете с DC системы, Период.
* Полностью закрыты, Вентилятор Охлаждения Двигателя: более Высокие скорости требуют вентилятор охлаждения двигателя, большинство DC вентилятор охлаждения двигателей полностью открытым для воды, грязи, пыли и песка. С нашей переменного тока Полностью Закрытые Двигателя, эта проблема осталась в прошлом!
* 100% Обслуживания: Электродвигатели переменного тока имеют ни Щетки для замены и не Коммутатор, на поверхности.
* Высокая Скорость Двигателя: Наш двигатель переменного тока может работать на очень высокой скорости без каких-либо возможность ее повреждения. Нет обмоток Якоря на перевязи отдельно, так Двигателя Скоростью до 6000 об / МИН даст вам 25 км / Ч без изменения передаточных чисел в дифференциальной и потерять холме восхождение момент.
* Безопасность: Держать на горе будет держать машину из откатываясь на холме, всегда нужно-включить стояночный тормоз, хотя.
* Тормозные Огни во время рекуперативного Торможения, Система автоматически переключается на тормозные огни, когда отпускается педаль газа и Регенерации Торможение применяется.
* Гибкость: Эта система может быть адаптирована к Физических потребностей. Если вы хотите различных Максимальная Скорость, более или менее рекуперативного Торможения или разные ускорения можно настроить под ваши личные предпочтения.
* Возможность обновления: Наши контроллеры, программное управление, так что будущие обновления, которые имеют либо скачать программное обеспечение или просто изменить "фишек".
* Система Включает в себя: переменного тока, Асинхронных электродвигателей, Электродвигатель переменного тока Контроллер, Электропроводка, Прерывистая Дисплей, Контроллер Пластина для Монтажа и Инструкции
* Установка: Мы предлагаем полный Монтаж на нашем Онтарио Центр.
* Гарантия: 1 Год, на Контроллер и Двигателя
Да, Паш цены "экологичные". Не ужели в оборонке не было таких моторов? ДПР с ромбом до сих пор продают.Может в авиации сервомоторы какие есть.Надо у Сани спросить.
LPB
Прогресс-2
HONDA BF-30
На парсуне мож и свет клином и не сошелся-хотя оч приличная фирма, есть еще
Torqeedo Electric Outboard Boat Motor Travel 1003 о винтах этой фирмы я постил как-то, но они больше к Мин Коте и на 12вольт основной упор, т.к акумули встроеные.
Есть конечно и до 50-60лс но ценник в 19000уе и это без акиумуляторов помоему,какой-то неправильный, ни один русский, если он не очень новый не захочет сохранять озоновый слой за эти деньги.
LPB
Прогресс-2
HONDA BF-30
Эти моторы уже из новых материалов (Permanent magnet motor(моторы с очень сильными магнитными полюсами) и прочие изыски)-скорей всего у нас не было.
Я думаю изыскания на этом закончились - ждем первую ласточку :hahaha: :hahaha:
Обычного среднего немца,жаба не задавит ,а раскатает за такие деньги. :D Далеко не у каждого з\п и половина от этой суммы.
Бешенный
Волгоградская обл Светлый Яр
Владимир Валерьевич
Все одно не отговорили.Пока почесываю репу и "проблему" из этого не создаю.Забить на это дело ни когда не поздно
AVSh
Ротан 380К
Хонда 20
http://www.youtube.com/watch?feature=pl ... Maxbdz-1aE
так можно сделать мотор - генератор. Если набрать 1 - 2 - 3 АКБ + один частотник, то таким мотором можно крутить гребной винт, а потом вешать на него парусное ветроколесо и АКБ заряжать.
buratino
Григорий
Катер Диана 3-01
Хонда 1.3
http://www.aliexpress.com/item/10x-5000 ... 72469.html
Набираем таких аккумуляторов. Цикл у них больше 1000.
Напряжение повыше сделать-ток поменьше будет.
Двигатель лучше бесколлекторный. Набрать статор из динамной стали не проблема. Медью намотать и ребёнок сможет. Ротор сделать, магниты неодимовые закрепить не сложно. Вот вам и электтромотор. Альтернатива бензиновому!
LPB
Прогресс-2
HONDA BF-30
Шибко много не наберешь, по 600 рублесов то за 3 вольта
buratino
Григорий
Катер Диана 3-01
Хонда 1.3
Вообще то 60 рублей штука.
AVSh
Ротан 380К
Хонда 20
Есть одна проблема - заряжать эти АКБ.
LPB
Прогресс-2
HONDA BF-30
Если человет взялся за самодельный электромотор, то спаять зарядное для литиевых батарей просто обязан.
Есть у них еще одна неприятная особенность- недают глубокого разряда-выключаются и все, причем сразу... :pardon:
buratino
Григорий
Катер Диана 3-01
Хонда 1.3
Так эта весьма приятная особенность. Не убьёшь большим током при разряде.
Супер_Олег
Днепропетровск
Колибри
Парсун
Доброго времени суток. Недавно поспорили с ребятами. Интересно мнение практиков. Сильно влияет на расход топлива температура воды? Интересует мнение по Парсунам.
Олег-Дмд
Самоделка Радуга 370, Каяк туристский КНБ 1990 г постройки, ПВХ 360
Ветерок-8, Minn Kota30
Такое вот видео попалось Весьма неплохо человек сотворил
voco60
Буревестник-390
Сузуки-30
Всколыхну темку. Отдал мне племянник гироскутер.надоел он ему, теперь ему прикольнее электросамокат. Что у гироскутера внутри? Всего то два BLDC двигателя по 350Вт, три платы, один аккум 36 В условных, где лития 10 банок по 2 А часа.
Валера на "Ты труба" три ролика выложил, показал эволюцию своего лодочного мотора. Моему техзаданию его результат соответствует. Тут кто то имеет интерес к малому ходу за сущие копейки? На Авито гироскутеры продают за 1-2 тысячи рублей. Регулятор скорости на Али до тысячи.
voco60
Буревестник-390
Сузуки-30
Вот ссылка
Реально круто, но ногу я бы взял от Салюта, там всётаки настоящий редуктор.
voco60
Буревестник-390
Сузуки-30
Сергей, для нас использование ноги плм - однозначно. Валера в основном занимается двухколесным транспортом, потому его и бросает от самодельного ГВ к ямаховскому, а потом к винту от электромоторов.
Вариант ноги нужно делать исходя из наличия ГВ разных диаметров и шагов. У гироскутеровского моторчика вращающий момент очень высокий даже на 12В. Погонять моторчик успел только от драйвера на 15А 12-24-36В и стартерной автомобильной батареи. Рукой удержать невозможно. Вижу реальную возможность сделать хороший движок для ловли в проводку с устойчивой скоростью от 0 до 5км в час.
Ещё можно бортики подрезать, на которые покрышка встаёт, мотор станет гораздо меньше.
voco60
Буревестник-390
Сузуки-30
Можно, но это мало даст по габариту, а вот теплоотвод от магнитов ухудшится.
Да, тормознул, тогда можно болгаркой нарезать лопастей, пусть и контроллер обдувает.
